Center line for fuel tank
WI
Hi everyone. It's been 11 years since I built a kit (getting back into the hobby) and I seem to remember something about the center line of the fuel tank being in line with the carb. Is this correct? Can someone direct me to a web site that goes over installing the fuel tank?
Thanks a bunch,
Larry
Thanks a bunch,
Larry
VA
RE: Center line for fuel tank
As i dont have a website to refer you to. However, you are correct. The centerline of the tank should be as close to being inline with the carb. Usually the tank position is more important on inverted mounted engines as if the tank is too high you could get a syphon effect, which could drown your glowplug. If you cant get it perfect then its fine you wont really notice a differance.
