 Problems with Zenoah G26 >
Old 12-04-2006 | 09:59 AM
My Feedback: (10)
Default Problems with Zenoah G26
My G26 quits when i roll inverted at high throttle settings. Ive had this problem since i first ran the engine. For peak RPM i leaned the engine almost 2 full turns. At this setting the engine doesn't stop while inverted but runs different. Is there something that i am overlooking. Ive cleaned the carb numerous times and experiemented with many needle settings.
Old 12-04-2006 | 11:41 AM
Bud Faulkner's Avatar
Default RE: Problems with Zenoah G26
If you post this in the engines/gas forum you will get a better response.
Old 12-04-2006 | 12:20 PM
MinnFlyer's Avatar
My guess is to take a look at the tank and make sure that your clunk is not stuck
Old 12-04-2006 | 12:27 PM
Good guess Mike, could be jammed at end.
