Help identify this motor/setup
I got this in a trade and would like to use it, but since I'm a nitro guy - don't know where to start. Motor has no markings but the esc is rated for 20 amps. Not sure what type of connector that is.
Soooooo - What voltage battery and amperage can I use and what type of connector is that?
RE: Help identify this motor/setup
sermos connector,looks like a simple can motor diameter of the can would help determine size.looks to be 400-600 size.7.2 volts should be safe,amps would be limitted to the esc.
