setup 2 elevator servos
I'm trying to use my RD6000 Airtronics transmitter to setup two elevator servos without using a reversing y harness. So far I haven't been able to figure out how to do it. Is the RD6000 capable of mixing the two and if so does anybody know how? I read the manual but couldn't see anything for what I'm trying to do.
With the elevator servos on each side at the rear of the fuselage, you'll need a reversing harness, or internally reverse one of the servos.
With the servos mounted forward inside, they can be set next to each other with no reversing.
Doh! and I loved my radio too. Oh well I guess I will just have to get a reversing harness. I cant place the servos inside the fuselage now because of the holes cut out for them in the sides of the fuselage.
