 Perry Pump testing >
Perry Pump testing
Perry Pump testing
Old 01-20-2007 | 07:39 PM
guille2006's Avatar
Default Perry Pump testing
Can anybody tell if is it any way to test the proper functioning of a perry pump? I do not trust totally of mine which is connected to a STG 90...
Thanks on advance
Guille
Old 01-20-2007 | 09:36 PM
Default RE: Perry Pump testing
what do you mean by test... if you want to see if its moving any fluid you could hook up an engine to run normmall bolt it onto the back and set up another tank that it would be coonnected too teh pump the second tank (pump tank) would be a look so that the out would go to the vent line in the tank and you could see if fluid is mooving (fill tank half way..)
