LED light
PA
This may sound like a dumb question, but has anyone ever hooked up a LED bulb to the on/off switch to indicate when the switch is on? Is it possible to do this? and if it is do you need something to reduce the voltage? I was looking for something simple to indicate when the switch is on.
Yup, you can get one here...
There is one version that monitors for radio and switch problems too.
http://www.centralhobbies.com/Electrical/LED/index.htm
