 Mounting AX 46 on Aresti >
Old 03-31-2007 | 09:25 AM
mvallyman's Avatar
My Feedback: (32)
Default Mounting AX 46 on Aresti
Id like to mount an AX 46 in an 8 O'clock position so that the muffler is down at the center. Problem Im having is that the muffler doesnt hang down far enough, it puts the crank about one inch below the thrust line. I need an extension about 1 inch long.
OS makes a muffler extension but its only 7/16" long, I could cut the fuse to accept the muffler hight but would like to hear more ideas.
Old 03-31-2007 | 05:14 PM
Default RE: Mounting AX 46 on Aresti
Dubro makes a 6' extension, it may be hard to find the right length bolts after you cut it to the size you need but it a direction to go. It should show up on their web site www.dubro.com ENJOY !!! RED
