SMOKE
Old 04-04-2007 | 11:41 PM
Default SMOKE
IS A SUPERSTAR 120 TO SMALL FOR SMOKE
Old 04-05-2007 | 12:36 AM
Default RE: SMOKE
G'day Mate,
It may be too young to smoke, but not too small.
Old 04-05-2007 | 05:33 AM
MinnFlyer's Avatar
Default RE: SMOKE
ORIGINAL: james e
No, smoke would work fine in the SS120
Read this:
http://www.rcuniverse.com/magazine/a...article_id=455
Old 04-05-2007 | 06:55 AM
Default RE: SMOKE
Nice article, Mike. I just put a smoke system on my WACO and found that even though I can regulate the pump speed through my Tx, I still need a "pinch point" in the line. I like the regulator you made and it will work perfectly in the spot I have available on the line. Thanks much. Ken
Old 04-05-2007 | 09:01 AM
MinnFlyer's Avatar
Default RE: SMOKE
Yea, I remember when i did my first smoke system... I needed to figure out how to get that regulation. My first thought was to get an air-regulator for an aquarium. I remember having a nice brass one as a kid, and I though it would be perfect.
So I went to the local Pet Store and nowadays all they had were plastic ones that were much larger than the old brass jobs - They had a few brass type, but they were multi-valve (Like 3 or 4) and pretty pricey.
So I had a delema. I thought, "There's gotta be a simple way to pinch a line". I was thinking all I needed was a "U" shaped piece of metal that I could drill and tap a hole in, but where could I find one?
Then I hit upon the idea of the dowel, and Voila!
BTW, another neat trick is if you have an old carb lying around, you can swipe the needle valve out of it and use that.
