WHAT ESC DO I USE???
CA
I JUST BOUGHT THIS MOTOR AND IT SAYS 45 AMP AND MAX AMP 50. WILL A 45 CASTLE CREATIONS BE ENOUGH OR DO I NEED A 60 AMP?
ITS A QUANNUM DRIVE 36-55, 5 MM SHAFT 1345KV 45 A
WEIGHT 220G
DIMESSSION 36MM X 55MM
PHASE:3
POLE 6
RESISTENCE : 0.03
INDUCTANCE: 0.008MH
NO LOAD CURRENT: 1.0A
LOAD CURRENT: 50A
TURN: 2
AVERAGE VOLTAGE: 24V
MAX VOLTAGE 28V
WEIGHT 220G
PHASE:3
POLE 6
RESISTENCE : 0.03
INDUCTANCE: 0.008MH
LOAD CURRENT: 50A
TURN: 2
MAX VOLTAGE 28V
VA
RE: WHAT ESC DO I USE???
I usually use the highest recommended speed control for the application. HOwever if your motor lists a max of 50 amps and normal current of 45 you will be fine with a CC45. Speed controllers take bursts of current for limited periods of time and not effect anything. If you use the 45 and you test the combo with a watt meter and its at the limits of the min current, keep it cool with proper ventilation and it would run like a champ.
