Receiver Compatibilaty
Subscribe
04-29-2007 | 07:05 PM
Hi,
I am a Futaba user and right now I am using the 6YF TX with an R147F RX, (both on 35MHz).
Now I am intended to upgrade my TX to the 7C but will the current receivers I have (R147F) be compatible?
thanks in advance for you help
Reply
04-30-2007 | 06:26 AM
RE: Receiver Compatibilaty
I am assuming you mean channel 35. not 35MHz
Yes it will work ok with your receivers as long as your new 7cap is on channel 35. The best way to get going with the 7 cap is to get with someone that already has one to help you out with the programming.
good luck
Reply
04-30-2007 | 06:36 AM
thanks for the help.
In the EU we use 35MHZ (in fact I use channel 68 = 35.080MHz)
But do you think that the modulation type matches?
Reply
04-30-2007 | 07:30 AM
I was using a 6XAS Futaba TX with 6, 7 and 9 channel 1024 PCM receivers with no problems. From what I understand, as long as it is a Futaba receiver, whether PPM (FM) or PCM, it should work with any modern Futaba TX. Upgraded to a 9CAP.
In Oz we use 36mhz.
Reply
04-30-2007 | 07:33 AM
In Oz we use 36mhz.
Reply
