Crystal information needed
I am trying to find a "mini dual conversion receiver crystal" on 72.490
(channel 35 ). This crystal will be used in a Turborix 8 channel dual
conversion PPM receiver.
I have contacted the few ads I have seen for the Turborix dual conversion
receiver and they do not sell the crystal separately.
I received the receiver as a gift and there is no information with it
and I do not know where it was purchased. The crystal that is presently
in the unit has "WFLY" on the tag. a 5/32" spacing between the pins.
Pin diameter APPEARS to be about 1/32". Bottom flange width is 5/16",
case width is 1/4",thickness is about 3/32" and case height from the
bottom of the flange is 5/16".
Any ideas/suggestions on what might fit/work ?
RE: Crystal information needed
Campy,
It does not look good found the Mfg. on this thread....
http://www.rcuniverse.com/forum/m_43...tm.htm#4331003
