Foam Core Wings. Light, or heavy?
Do foam core wings build heavier or lighter than built up wings?
I'm contemplating building Miss Norway to learn a new construction technique, and use for sportsman pattern along with my or instead of my Ultra Sport. It is supposed to handle crosswinds exeptionally well (according to RC Modeler Magazine's "Flight Training Course" for pattern{Antiquated now, but still usefull.}).
If I can learn how to cut foam cores well, maybe it might be worth my while to cut foam cores for the Ultra Sport as well.
Upon browsing the archives on this subject, there really wasn't much that jumped out at me as to this particular question.
My Feedback: (53)
In general foam core vs built up are very close in weight when the foam core wing is properly built. But too much glue and/or heavy wood can quickly cause the Foam core wing to gain alot of unwanted weight. The sheet attachment methods vary with contact cement or very thin layer epoxy being the traditional methods. The old D&B kits use a almost totally sheeted wing meaning that the foam core was cut with the leading edge. So you have to sheet around the leading edge which could be somewhat challenging. Traditionally you just sheet the core, glue on a balsa leading edge and whatever it takes for the trailing. Cutting foam cores is not a real hard thing to do.
depends on the foam used,but if you use one pound/cubic foot eps foam[virgin] it is the white foam.typically they built the same weight as a built up wing but are alot stronger.as far as cutting your own ,it can be done but for the cost of shipping the blank foam to you and the equipment it is easier just to buy the core allreadycut.I believe there are miss norway cores available.try here
http://www.dbalsa.com/foam_wings/alphabetical.htm
I think foam is always going to be heavier than built up.
Whats all that space between the ribs in a built up wing? Air
Whats air weigh? Nothing
Whats foam weigh? Solid foam wing?
Even using 1 pound density foam--compared to 8 pound balsa. I still think balsa built up is lighter than foam. There is very little of that balsa in a built up wing.
Thats my totally biased opinion because I prefer a built up wing over foam sheeted. IMO--sheeting foam wings is a pain in the butt. I can frame up a wing pretty quick.
With a little of experience you can build a vey light ribs and sticks structure, meanwhile you don't have this option with foam.
As a result, a foam core wing is heavier.
My frustration lies in lack of experience. Not many other ways to put it.
I would like to learn this technique (cutting foam cores), as I think it is helpful to me for future modeling, but I am also fighting my own skills, or lack there of. I've built quite a few kits and done well, but now I am getting into the realm of cutting my own wood and weighing it. (This is important when you want to build and compete.) Quite frankly, I have no base/experience for comparason in choosing wood to build lite, but strong. There are a ton of books and reference material to look at (which I have and am using), but experience is what is going to dictate a great build. I've simply never built with foam.
I am wanting to get into pattern, but classical pattern, which at this point limits me to sportsman class or the SPA, which is just fine, since I have much to learn. But the aircraft needs to track straight, power through LARGE loops with reserve power, and be competetive. I'm a little overwhelmed, yet quite excited to get my hands dirty.
This may need to be moved to the pattern forum, but I did get answers to my questions. So, thank you everyone.
My Feedback: (9)
FL
ORIGINAL: Rcpilet
This brings the weight of the two types of wings very close to each other, particularly when speaking of larger sized airplanes.
I find foam core wings much quicker to build up but they do require some aquired experience, particularly when cutting out control surfaces, planning for retracts, etc......
ORIGINAL: branded
Uh, air has weight to it just as any other fluid. What's in a built up wing is alot of stuff not found in a foam core wing: ribs, spars, shear webs, etc.
ORIGINAL: Rcpilet
I kow how to build a foam wing. Done a few dozen of them. I just don't like it.
You still have spars in some foam wings. You still have a leading edge piece of balsa on the wing. You still have a trailing edge piece on the wing AND another leading edge piece on the control surface. You still have caps on the root and tip. Just like a balsa plane.
A balsa wing isn't always sheeted on the whole wing--so there is weight savings over a foam wing. A balsa wing has a lot of air in it and air weighs less than foam--I don't care what planet you live on. Foam is heavier than air--thats the point.
Look how much more glue it takes to install a phenolic tube in a foam wing as opposed to a built up wing. On a foam wing, you really should be coating the entire socket with glue and making sure you get glue on every part of the tube when its in the socket.
In a built up wing, your only going to put glue where the phenolic touches the ribs. If your a good builder, you wipe off runs and keep the glue neat.
Glue weighs something. There's a lot more glue in a foam wing than a built up wing. I certainly think there is.
Okay, your turn ....
Maybe we should do an experiment? I'm fixin to build an 80" wing with about 980 sq.in this summer. It will be a traditional balsa wing. Maybe I should weigh it as I build and you should start that kit you've been eyeballing for the last 2yrs. You know, the one with the foam wings?
My Feedback: (9)
FL
ORIGINAL: Rcpilet
I disagree about air having weight to it. Thats an argument over symantecs and pointless in this discussion.
ORIGINAL: branded
ORIGINAL: Rcpilet
I only speak from 35 years of experience....I've built both kinds of wings. Foam core wings require less structure and are inherently stronger.
Yes, there are spars and structure in a foam wing but far less than that of a built up wing....which makes up for the additional volume of the foam....
Helium anyone?
My Feedback: (9)
FL
ORIGINAL: Rcpilet
I can't cover well enough to keep the helium trapped inside for any length of time.
Given the geometry of the wing is fixed, you can either displace the air with spars/wing ribs/shear webs, or spars and foam....either way your filling the space with "something"...and yes, air does have a weight....
Cheers...
Rcpilet:
Why would you have to fully sheet a foam wing? Couldn't you sheet the way you would on a built up wing? That would mean to cut cap strips and leave the "rib bays" open- with exception to LE sheeting to the spar, and TE sheeting?
Of course the foam would still be there, but between the covering and the sheeting with mock cap strips, there would still be a lot of strength, fooling the normal eye to a regularly stick built wing. Wouldn't there?
ORIGINAL: branded
Well, please revert to your H.S. Physics....When you add "anything" to a container, this time a wing cavity pf a given volume, you displace the air inside with that "anything".....
Cheers...
ORIGINAL: Rcpilet
Cheers...
But, your not acknowledging my point.
Air is lighter than foam.
I still like built up wings better. I think they are lighter. A foam wing is easier to repair though.
My Feedback: (9)
FL
ORIGINAL: Rcpilet
I concede your point. Air has weight.
ORIGINAL: branded
Cheers...
ORIGINAL: Rcpilet
Cheers...
The fact is, with a given planform, when using a foam core you can actually reduce the sheeting thickness because foam has more structural strength than traditional "eggshell" construction.
If the plan calls for 3/32" sheeting for a builtup wing, you can use a 1/16" on a foam core wing....
The downside of a foam core wing is as I said, it's not for novices. There are assumed, or aquired skills, that not all have, not to mention some tooling such as vacuum pump and bagging equipment.
The fact is, if an experienced builder is given the task to build both, they will be nearly equal in weight; however, the foam wing will be completed in far less construction steps.
branded:
Sorry, this is where I will disagree. You do not need a vacuum pump and bagging equipment. True, that is one method to cover the wing, but plastic covering is very strong and is plenty to cover a finished foam core wing. A tried and tested method as I have witnessed myself.
Excuse me for entering in this discussion without an invitation but I really got confused of what you said.
What air, helium and inflating the wing have got to do with this?
Come on guys, be seriuos!
Light or heavy means what you read on the scale display which converts into wing load. That's it.
Since we are talking about wing weight, I also disagree about repairing foam core wing.
It may be easier but the additional weight it causes is huge, whereas when you repair a build up wing its weight will be the same afterward.
I'd like to point out one more thing. In a built up wing the covering film is part of the structure, it provides stiffness and stength unlike for the foam wing is only an esthetic application.
This has been neglected and I think it would be worth to mention rather than the amount of glue needed when building one or the other, which is a very subjective factor.
One more question. Which building technique do the sailplane guys adopt for their 10 feet wing span-and-above creations? Are they keen on light structures or do they like thier planes diving like P 51's?
ORIGINAL: PiccoLino
ORIGINAL: Ilikebipes
branded:
branded:
Warbirds, in particular will be sheeted (now I'm only talking about wings now, as that is the topic at hand).
Some guys use the shucks to sheet the foam wing by placing heavy weights on them until the glue sets but it's really best to use vacuum bagging technique.
ilikebibes,
the feathercut foam wing cutter I mentioned in my last pm is available here
http://www.tekoa.com/
you don't need to fully sheet a foam wing. You can just sheet the LE and TE and then add cap strips
Why do the bays have to be removed you ask? If the foam is not removed, when the covering is applied it will sag between the cap strips and stick to the foam. The result will be one awful looking wing with sort of flattish patches in every bay and a truly wierd airfoil. It will be a mess.
Ed S
I just completed an Akrobat (75" span), a Gerry Graham design from back in the late '80s. He kitted this plane and provided a roughly framed jig build fuselage and mostly finished jig built wings. My kit lay in the barn for twenty years waiting to be built but is now flying.
Gerry used foam ribs with cap strips, which results in the lightest wing of any plane I've built.... but I gotta agree that of the foam wings I've build, they seem a slightly heavier.
btw, I scratch built a Simitar many years ago using a self cut foam wing and used cap strips and had no problems with the covering touching the cores... so I'd argue that cap stripping can be done.
My Feedback: (7)
LA
If you're going to argue, add some fact please. Like what is your weight per sq foot or sq inch?
I just built a 54" span wing for a sport plane. It was covered in tyveck and had a heavy wood spar. It weighed in at 4.66 oz per sq ft.
Someone else gonna add some fact here?
ORIGINAL: batchelc
You can get plenty of opinions though.
