Seagull Yak Antenna
NC
Seagull Yak Antenna
The Seagull Yak has a tube for the antenna that runs almost parallel to the pull/pull wire on the right side and exits the fuse about 1/2 inch from the pull/pull wire. This makes me nervous. Has anyone experience with this setup? Any interference problems? I am using a JR PCM receiver.
RE: Seagull Yak Antenna
G'day Mate,
Pull/pull wires won't cause interference, metal to metal contact might, & close proximity to servos will.
You should be OK with this setup.
Be sure to range check.
