Can't read voltage on RX Battery
CO
Can anyone offer up the potential problem to this situation.
A plane I was once able to read the voltage on the rx battery now will not show the voltage. It reads something like -0.04 volts. However the plane does take a slow charge. I had a problem fast charging it too but suddenly that works now. I can't easily get to the battery, other than via the charge jack wire. It seems to hold the charge ok but I don't like not knowing my voltage. Yes I did make sure the rx switch was "off".
Thanks for any insights into my situation.
ScaleMe
ScaleMe
You have a problem which, if you value your plane, will have to be solved even if you have to remove the equipment from the plane to do so. Sounds like a crash just waiting to happen.
FL
If you can't meter the voltage through the charge port, the charge is not going to be reliable. Assuming there is nothing wrong with your voltmeter and you are connecting the leads correctly, one guess would be a loose solder joint in the battery pack.
Rodney is right. Wwhenever a battery pack starts exhibiting inconsistencies, it's best to replace it. $20 of prevention is worth $200 of cure.
One last thing. The problem may not be in your battery, but in the switch/charge port harness. You should first eliminate that as a cause by testing it thoroughly with a different battery pack.
- George
- George
GA
- George
- George
