silicone deflectors
NE
silicone deflectors
What is the best way to keep one of those Hobbyco silicone deflectors on? I have an OS FS 52 surpass II and there just isn’t enough room for two zip ties and one doesn’t cut it.
This is on a GP Cessna 182 and I would like to get the exhaust out of the recessed cutout?
Any suggestions?
Would RTV stick to the deflector, or would I be better off to grind a recesse around the muffler?
Are there any other suggestions?
Any suggestions?
RE: silicone deflectors
On a two stroke I drilled a 3/64 hole through the deflector and muffler outlet. I ran .040 stainless safety wire through it and twisted the ends. It will not fall off.
VA
I had the same issue with my saito 100 and i used a dab of JB weld around the tip of the muffler. AFter that dries put the deflector on and zip tie it. The JB weld acts as a lip so the ziptie or deflector wont slip off. Works Well...
