Saito 82
Saito 82
Hi
What do you guys use to hold your sait 82's to your engine mount... I had 6/32 steal bolts one inch long with locking nuts on the end this worked great but after about 5 tanks of fuel and one flight i came to remove the engine so that i could add more right thurst and found that all four bolts that hold the engine to the mount are bent so I have to replace them what kinda of bolts do you use titanium? tongston carbid?
Steven
Steven
RE: Saito 82
I use 6-32 consumer quality steel screws without any problem on my Saito 72. The idea is that the screw creates contact pressure between the enigne and the engine mount. The friction of the contact is what holds the engine in place, not the screw. Maybe your screws were not tight enough?
One can get high-strength steel screws and titanium screws from an industrial supply house like McMaster-Carr, but they are expensive .
RE: Saito 82
ORIGINAL: sacgate
I also own that engine but I have yet to use it. I assume it performs well?
so far (i have only had about 2minute on the sticks) this engine preforms great it pulled my 6+ pound plane verticle and wasnt showing any signs of slowing down at about 70% power but i didnt push it to see what it would do because it needs ALOT more right thrust in the time it took my to climb about 250 feet verticle with no rudder input (test to see if i ahd enoguh right thurst) the plane was at 45* side ways it had pulled so much to the left[]
it looks like it well be a great preformer, the dead stick was my stupidity tryign to get a low idle... there wasnt enoguh sunligh left to tryanother flight that day.
RE: Saito 82
Steel bolts come in different grades , you may have used a low grade, which are much softer than the higher grade. I use Dubro Hex head socket bolts on my Saitos with out any problems
MB, CANADA
RE: Saito 82
I have 6x32 allen screws holding my saito 120 with no problem; you must have very soft screws. That engine will only provide a pull of about 6 lbs static and far less in the air.
WA
RE: Saito 82
I use 4-40 stainless machine screws and have no problem with them bending on my .82. 12x9 pulls about 6 1/2 lbs. 13x7 pulls 8 lbs. 14x4 pull about 9 1/2 lbs. This is a very strong engine in a small package.
RE: Saito 82
ORIGINAL: Ed Smith
Is the bottom surface of the beam mount parallel with the top surface if the beam?
RE: Saito 82
If you can file or sand the bottom of the beam parallel to the top, I think the problem will go away. It doesn't have to be perfect, but it needs to be as close as possible.
WA
RE: Saito 82
Scratch only. To answer your question: by testing of course. Perhaps you should experiment or actually own an engine before you comment on its performance.
RE: Saito 82
I own this motor and it is a nice running little power plant. It seems to have a vibration band just above idle and I stay away from that throttle setting. Make sure you are ballancing your prop and spinner. I use only socket head cap screws to mount motors. These are an industrial fastener and are much harder than usual hardware which is soft and can stretch. Just my 02 worth.
Blue skys.
JEB
Blue skys.
JEB
