Bomb Bay doors.
RE: Bomb Bay doors.
I know my drawing really sucks but this is how i would do it.
Its basically a simple box with a servo mounted on the bottom of it, it has a simple peace of that umm flexible push rod stuff (i think its called nycrod?) the red dot is a simple hing that holds the bottom on the push rod is in the middle of the box while this does obstruct it a little bit it shouldnt matter much
just one warning make sure that when its done the box is mounted so that it opens towards the wingtips this way the servos doestn have to try and puch an air brake through the air
AR
RE: Bomb Bay doors.
there was a us aircore plane back in the 90s that came with it. i'll try to remember the mechanism. it was fairly simple.
Do you need one or two doors?
RE: Bomb Bay doors.
A door isn't anything different than a landing flap on a wing. Except it isn't on the wing, it closes a box. You hinge a flap and drive it with a servo. In this case, the flap is a bombay door.
RE: Bomb Bay doors.
To do any good, there has to be a fair amount of candy. So you need a big box.
Spring load the door(s) and have the servo release the door latch. That way the servo doesn't experience any load. It doesn't have to hold the doors closed or force them open. Triggers are useful things.
RE: Bomb Bay doors.
One of mine uses a cable latch release to open the door, the weight of the candy actually opens it when the latch is released. The door also has a small magnet in it to hold the door closed after the candy is dropped. The door swings down and forward so the wind will tend to close the door. I usually do a Victory roll after the drop and that lets the door close by itself. ENJOY !!! RED
RE: Bomb Bay doors.
I just cut a couple doors in the belly of my F22. I didn't think about the latch, I used an old set of mechanical retracts and a retract servo.
