How do you remove lock-tight???
Hey guys I used lock-tight (blue) on the flex shaft coupler that screws on to the engine. When I tried to remove the coupler, the threaded shaft came out of the engine and still has the coupler attached to it. Is there something that I can soak it in to loosen up the lock tight? WD-40, antifreeze in a crock pot, denatured alcohol, etc. Please let me know!!!
Thanks guys!!! That makes perfect cents! I never thought of that I'm really glad I asked before I tried something else. Thanks again Dale
