Prop Size ?
Thanks Stick Jammer
The manual does recommend those props, but states it is a starting point. Slightly larger or smaller props can be used.
Guess I should have mentioned the engine is in a Big Stick .40.
I am wondering if the engine can be damaged, or if a plane just won't fly if it is under-propped?
__________________
__________________
GA
4 strokes can be damaged if they over rev. You need to keep the rpm's in the suggested area for best performance. If you over rev you can float the valves and that can create a problem. It is kind of like driving your car way past red-line. Something is going to give.
