Saito FA 120 help needed.
Hi, first time here on this q&a forum.
I have a Saito FA 120, it's the one with a threaded rear facing exhaust, on the right of the head, and the intake on the left that uses an oring seal to the intake manifold(unthreaded). I think this is about 15 years old, not sure of the version.
The exhaust cam is loose on the shaft and makes a click at the engine is rotated, right after the lifter goes over center on the cam. Is this normal for Saitos? It doesn't seem right.
Where can I get a screw and gasket set, along with a new cam for one of these engines?
TIA, Jay.
TIA, Jay.
