powerbox sensor switch
hi out there, im building a cm-pro extra 300s ,i have a powerbox sensor switch and two lipo packs .i have not use this sort of thing before ,i have found that the lipos have a different plug than on the sensor switch .any help on how i connect it all up would be a great help,pictures would be even better .
Hello
Sensor switch is a great product.
Plug one of the plugs into the usual battery socket on your Rx, plug the second plug into any spare channel socket 6-7-8 etc.
The batteries plug in as usual, as long as you always plug the batteries in the correct polarity blue=black.
If you have red JST connectors on you battery they still fit the PB socket as they are 2/3 a standard socket
Any more help you can phone 01923 270405
Dave Wilshere
Dave Wilshere
