Prop Selection
TX
What's yalls suggestions on props for an OS .46AX/4*40???I ran it in on the bench with a 10/6 as the spec suggested.....I was planning on going with an 11/6 to start out flights.
Thanks.
Thanks.
Keep in mind:
GIVEN THE SAME RPM
A large diameter/low pitch prop will give more pull, less top speed.
A small diameter/high pitch prop will give more speed, less pull.
It's simply a matter of how you want the plane to fly. I'll agree with MinnFlyer, the 11-6 is a good place to start.
Dr.1
GIVEN THE SAME RPM
Dr.1
ORIGINAL: Dr1Driver
Keep in mind:
GIVEN THE SAME RPM
Dr.1
Keep in mind:
GIVEN THE SAME RPM
Dr.1
