Perry Pump Question
My Feedback: (33)
Hello all,
I have a plane with the fuel tank mounted above the carb on an inverted engine. Will a Perry pump (v-20) help any? I know that dropping the tank would be the best thing but it wouln't be easy. I was thinking that the pump would even out the fuel flow and help on flooding while at idle. Any thoughts on this would be helpful as I have never used a pump before.
lets see ,if your fuel tank is higher than your carb you are goung to flood out no matter what you do.the perry or cline will not stop this as they don't have a valving action when not in use.i would drop my tank as close to the carb level as i could and then run my fuel line thru a fueler that i could put the plug in when not running the motor
My Feedback: (33)
I already do the plug in the fuel line trick, I am going to exchange my vp-20 pump for one of the ones that run off the crankcase pressure. From what I have heard that will Help some sense it is a regulating pump.
All else fails I will do surgery on the plane and drop the tank.
Thanks again,
me
Thanks again,
me
If I read the poop on the Cline Proportional Control Fuel System correctly, it is supposed to take care of your problem, Brandon. See what you think:
http://www.billsroom.com/pcfs/fuelsysdesc.htm
The fact that the system uses a check valve, and acts on carb demand only seems to overcome the gravity issue.
pj
pj
