cutting .040 aluminum?
IL
I want to design and build landing gear for a park flyer out of .040 aluminum. Does anyone know where to buy .040 aluminum? What do I use to cut it? What type of drill bit should I use to make lightening holes? Is there a certain type of sand paper I should use to smooth out the edges? Any input would be helpful.
MI
RE: cutting .040 aluminum?
How much are you looking for ?
You can cut .040 with good tin snips..then file the edges smooth...
As for lighning holes..the best thing to use is a step drill..ie. Unibit.. they will make beautiful round holes..not the typical triangle holes from a standard bit.
If .032 thickness will work you can get 4x10 sheets from Tower
http://www3.towerhobbies.com/cgi-bin...?&I=LXR911&P=0
They also sell .064 thickness in 4x10 and 6x12 sizes.
For sanding, if filing the edges doesn't give the finish you want, you'll need to get a 'wet or dry' aluminum oxide paper. The most common brand around here is 3M and you can get it at Walmart, Lowe's, Home Depot, Auto Zone, and many other places.
