Jr Xp9303 H
MI
Jr Xp9303 H
I have a JR Xp 9303 H on 2.4 ghz. It has the module in the back with a wire going to the antenna. Can this transmitter be converted back to 72 MHZ? I have been spooked on 2.4. Crashed a brand new AVA for no apperent reason. I was using a DX 7 transmitter at the time.
WI
RE: Jr Xp9303 H
Yes it can be converted back to 72 Mhz. Remove the 2.4 Ghz module and antenna and reinsert the 72 Mhz module and antenna. Set the transmitter back to PCM and you're good to go. I did the exact same thing with my XP 9303.
Birman
Birman
MI
RE: Jr Xp9303 H
Thanks for your quick reply.. I am going to do it. I am wondering what receiver to get. It must be small but with very good range. We fly high and quite far away. Any recomendations?
WI
RE: Jr Xp9303 H
This receiver comes with the XP 9303. It's a bit pricy, but worth it. JR does have some less expensive receivers with less channels. It all depends on what you want to spend. Be sure to get a PCM receiver
http://www.horizonhobby.com/Products...odID=JRPR649**
Birman
Birman
