battery
OH
Hi Guys,
I have a 4.8 volt receiver battery that went for a swim under a fuel tank with a 3/16" hole. What should I do to make sure it is not damaged? Any thoughts would be great.
Matt
Matt
It won't hurt to remove the outer shrinkwrap and rinse it off well with denatured alcohol then air dry. You can then just wrap in tape or put on the proper size shrink wrap if you can locate some. Generally, the components of fuel will not cause an electrical problem. It is just nice to get all the oil off as it will collect dirt as well as being just plain messy.
