Help with Battery!
Hey everyone!
I need some help!
I have a Katana mini which needs a battery! Here is the setup
Hacker X-30
Hacker A30-28S brushless MotorCan anyone recommend a battery and charger to suit this, or even if you have a spare lying around that you don't need! All replys are thanked!
Jack
I need some help!
Hacker X-30
Jack
NJ
Depends what you want. Go with a 3S Thunder Power 1320 if you want a light feel, or with the 2100 for duration. You could even get one of each, since those are pretty standard size batteries and either will come in handy for other models. You should be fine if you keep the battery selection within that MAH range. I suppose the brand isn't actually that important, as long as it's something quality. Eflite now makes some nice 11.1 batteries around that size too. Keep in mind how much the plane should weigh when it's completed. Weigh it, then compare battery weights online at their respective websites to see where you need to be at. You can't go wrong with a Triton charger IMO. Hope this helped...
