battery question >
battery question
battery question
Old 05-09-2003 | 01:50 PM
Default battery question
Can I "cycle" my tx and rx batteries by simply leaving them turned on and then re-charging?
I keep trying to go out to the field, and another dang storm comes up-
Cheers, Brett
Old 05-09-2003 | 02:02 PM
Charlie P.'s Avatar
Yes, as long as you don't let them drop too low before recharging. It is my understanding you don't want to let NiCads drop below 1.0v.
Old 05-09-2003 | 02:25 PM
And provided you don't mind the possibility of damaging your transmitter. If you're going to do it make sure you have the antenna extended. There's really no need to discharge the batteries though.
Steve
Old 05-09-2003 | 03:33 PM
Steve
Educate me.
Old 05-09-2003 | 05:09 PM
Thanks guys- I'm in the dark with the antenna bit as well- what's up with that?
Cheers, Brett
Old 05-09-2003 | 07:26 PM
If you run your xmtr with the antenna down, the SWR (standing wave ratio) goes way up and causes excessive heating in the output transistor which reduces its lifetime, possibly leading to instant failure. Did you ever notice how hot the back of your transmitter gets when you run with the antenna collapsed? Because the high SWR is causing the output transistor to heat up.
Old 05-09-2003 | 07:30 PM
Rodney has it. Radios are meant to work into an exact load, the fully extended antenna. Mess with that load and they can overheat and die.
Steve
Old 05-10-2003 | 10:18 AM
good to know....thanks guys
