 Engine cleaning? >
Engine cleaning?
Engine cleaning?
Old 06-16-2008 | 09:33 AM
Pete737's Avatar
Default Engine cleaning?
was just wondering if their is an easy way to restore a good finish to an engine. My buddy said something about antifreeze? I figured a good run on the wire wheel would help.
Thanks. Pete
Old 06-16-2008 | 11:49 AM
My Feedback: (20)
Default RE: Engine cleaning?
Yep, cooking the engine in a crockpot on high with old style green antifreeze will clean it up. Must use heat and since the antifreeze is poisonous, don't ever cook in the crockpot again. I suspect the wire wheel will scratch the soft aluminum parts of your engine.
Old 06-16-2008 | 12:36 PM
JohnBuckner's Avatar
Whatever you do if resale of the engine is ever a possibiltiy down the line then stay aways from it with a wire wheel or manual wire brush.
If it were a collectable type then doing that would instantly make the engine pretty much worthless.
John
Old 06-16-2008 | 02:34 PM
My Feedback: (47)
Pete, there is a ton of info on here about cleaning an engine with anti-freeze and a crock pot. the one thing you do not want to do is to cook it on highonly use low as high will ruin the looks permently.
I agree that a wire brush would not be a good idea.
Fred
Old 06-16-2008 | 03:09 PM
Pete737's Avatar
Thanks guys.
Pete
Old 06-16-2008 | 04:36 PM
rwright142's Avatar
Try Dawn Power Dissolver. Spray on, wait a minute, wipe off.
Here is what I did for a muffler: [link=http://www.rcuniverse.com/forum/fb.asp?m=5929584]Removing Glow Fuel Residue[/link]
