Epoxy types
My Feedback: (35)
WA
Epoxy types
Is there any difference between the 30 , and 45 min epoxies sold at Hobby Stores and the ones found at Home Depot, Lowes which also carry brands like Pacer, Devcon etc. ? Tks
My Feedback: (194)
RE: Epoxy types
I have not found any significant differences in the different brands of epoxies.
However, there is an important difference in the time in which they set. Slower is better, in that it not only gives you more time to position and clamp or pin the parts, but more important, it gives it more time to penetrate into the parts for a greater bond.
Fast setting epoxies result in a surface bond, with resulting less strength. Fine for a field repair but not the best during initial construction.
RE: Epoxy types
Just to add to EloyM's post. I use the faster 5-10 minute epoxies on foam where a surface bond is ok. The slow 2 hr. epoxy is great for high stressed areas, laminating and fuel proofing.
RE: Epoxy types
there are only two types of epoxies, resin and polyester. I have for years now bought from walmart 30 minute and 5 minute resin epoxy. for starters it comes in a more convenient size as to not go bad if sitting for too long. In the bigger sizes that the hobby stores sell it goes bad before I use a whole container. Walmart sometimes will sell polyester epoxy in the boat and body shop area. if you need a slow 2 or 3 hour epoxy that is the way to go.
Ed S
