 Something Extra Control throws >
Old 08-04-2008 | 07:37 PM
Default Something Extra Control throws
I just got a Sig something extra and need the recommended settings for the control surfaces. Any help is appreciated.
Dasflugmodele
Old 08-04-2008 | 10:29 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Something Extra Control throws
Elevator: Low rate - 1-1/4" up, 1-1/4" down
High rate - 2" up, 2" down
Ailerons: Low rate - 1" up, 1" down
Rudder: Low rate - 1-7/8" left, 1-7/8" right
High rate - 2-1/4" left, 2-1/4" right
CG: 3-1/2" back from the leading edge of the wing
Hope this helps
Ken
Old 08-05-2008 | 06:59 AM
Thanks for the reply. Seems to me it would be pretty touchy with that much throw. I have it set a lot less now and not flown it yet. Have you flown one with this much throw?? the balance is right on so I will give it a try and hope gravity is kind to me as it has been an enemy it seems.
Das
Old 08-05-2008 | 07:20 AM
My Feedback: (9)
If your transmitter has exponential on it , really works great on this type model. Good luck, Max H.
Old 08-05-2008 | 07:22 AM
krossk's Avatar
My Feedback: (27)
At the recommended throws, it's still pretty sensitive on low rates if you aren't used to it.
I found that after flying my Tiger 2 with increased throws, I was still a little nervous with the SSE on low rates.
I ended up taming mine with about 30% expo until I got used to it. On high rates, it will roll faster than you can count them and still pay attention!
Old 08-06-2008 | 12:16 AM
Beware of the roll rate as it is phenomenal and will distract you from seeing the ground coming up fast
If your engine has the capability, try going vertical with max throws on ailerons, THAT looks wicked
