 Spektrum Crab function >
Old 09-20-2008 | 12:09 AM
Default Spektrum Crab function
Th is my first post to RCUniverse, I have heard of setting up your ailerons and flaps to operate as "CRAB". Flaps full down and ailerons full up? Thus getting "air brakes" So my question is: Can a Spektrum AR7000 be set up this way? I read the manual and didn't find anything. My Spek is a year and 6mo old and before that I don't think Crab mode existed? Or did it? Any help would be appreciated...
OneXflyer
Old 09-20-2008 | 04:25 AM
Default RE: Spektrum Crab function
You might contact Spectrums' ,Consumers dept. (info should be in the manual) >>>-> bassfish [sm=shades_smile.gif]
Old 09-20-2008 | 07:22 AM
I believe you mean "Crow" instead of crab. You did not state what radio or plane you were using, so only a general reply is possible.
Go to http://www.horizonhobby.com/Products...ProdID=HAN2350
and click on the support tab. You will see programming instructions for many radios. Some of the mixes described are for the crow function.
Dave
Old 09-20-2008 | 08:33 AM
Sorrry~ The plane is a ultra stick 60 and the radio is a Specktrum ar7000
Old 09-20-2008 | 10:04 AM
It is in manual. Look up flaperons. I could tell you what page but think you should manage that.
Old 09-20-2008 | 07:57 PM
a crab is when the airplanes flies "crooked" because of a crosswind...I do believe you mean crow
Old 09-20-2008 | 09:36 PM
thanks for the grab vs Crow... Crow is correct. I'll try the Flaperon section. Thanks.
Old 09-29-2008 | 12:21 PM
onexflyer,
Sorry to tell you, but the DX7 Spektrum system does not allow for crow mixing between the ailerons and flaps. I have the same set up and read through the flap set up section with no joy. You can set up for tighter loops by mixing flaps and elevator to include setting up flaps and elevator for landing.
Brad
Old 10-02-2008 | 08:56 PM
FILE IFR 's Avatar
Just to comment on "crow", the ailerons should never go "full up", just slightly up.
Old 10-03-2008 | 07:19 AM
propbuster's Avatar
Hey Mike, "AOPA 5081747 ~~ Keep the ADF spinnin" Not if you're IMC!!
