Magnum 160 twin crankshaft not long enough...ideas?
My Feedback: (77)
AZ
Hello, I have a Magnum/ASP 160 twin 4-stroke (same as an OS 160 twin) and the crankshaft is not long enough to screw on an APC 16x8 and the nut (the propellter alone goes to the end of the crankshaft). Any ideas or workarounds?
RE: Magnum 160 twin crankshaft not long enough...ideas?
I don't know why you are having problems, I have the same motor in a Christen Eagle and the prop nut is too long. It goes through the prop and bottoms out on the spinner before the prop is tightened. I had to use a washer on the nut to get the extra room.
Cheers
Cheers
MI
did you get the engine new, if not someone could have cut the end off.
They make a long nut that goes down into the part that it is to hold on, not sure if its a good thing to do for our props but they do. You would have to ream out the hole bigger. and use a heavy washer. I don't think I have one, but if I come across one I will post a pic.
Remember your nut should thread onto the threads of the crank, at a depth equal to the outer diamater of the threads. Example if the threaded shaft is 1/4 inch in diamater, your nut should come into contact with 1/4 inch of threads. Do not try and thread it on just a little and try and get away with it. This is how you get max. holding power from the threads and nut.
Is there a different prop with a thiner web to it that will work?
sticks
sticks
ORIGINAL: teryn1
I had to drill the prop to fit over the shank of the nut. Have had no problems.
Good luck,
Dave Olson
My Feedback: (77)
AZ
Thanks for all the help. My goal is to put a prop nut or prop hub. But the "barrel nut" (long nut that slides inside the prop) that you guys are referring to is bulky. The one I have works but I'd like to get rid of that and put a Truturn prop nut or prop hub on it. I know I am asking for a lot but I thought i'd try.
Teryn
Teryn
ORIGINAL: teryn1
Bill, AMA 4720
WACO Brotherhood #1
TX
By looking the pictures I can tell that it is very weird that the shaft is that short. Let me ask you a question, in picture # 2 looks like there is still room between the prop and the flywheel, is it correct?
If there is still room there, you should use a prop reamer as Stickbuilder mentioned to get the prop flush with the flywheel.
If they are already in tight contact and still there is no room in the shaft for the nuts, then it could happen that it is extraordinary short, and you should send the engine for service (to change the crankshaft).
Regards
Alfred
Regards
Alfred
Why do you need to. The orignal nuts that come with the endine protect the crank if you are worried about that. If it is for the starter you may have to have something made, as I don't know any that would fit as the nut setup is a locking nut set. If it is for mounting a spinner mine has a 2.5" spinner.
Cheers
Cheers
ORIGINAL: alfredbmor
Regards
Alfred
Regards
Alfred
Bill, AMA 4720
WACO Brotherhood #1
MI
HI,
after looking at the pic's , I wonder if the threaded end of the crank does not unscrew and become longer or shorter?????? I have seen some RC engines with a prop screw that can be unscrewed and can be replaced. If you could put two nuts on the thread and tighten them together and then try and unscrew the threaded end from the engine. DO NOT PUT ANY WRENCH ON THE BACK PLATE FOR THE PROP, you do not want to mark or distort that back plate.
Get back if you find out its removable!
sticks
sticks
Geez,
Read my original post. I have explained how the engine is set up, and what kind of prop nut is used on the 160 twin. The shaft does not unscrew for adjustment.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
TX
Yes it looks very different than all my single 4 stroke engines (where the shaft is longer).
But you are right Stickbuilder
By the way I have not seen any crank shaft that could be unescrewed to become longer, which engines are those?
Bill, AMA 4720
WACO Brotherhood #1
ORIGINAL: Stickbuilder
I have not a clue, but who would want to do something like that anyway? Anyway, what I posted is the real skinny on these. If you can't get the Barrel nut, lock screw and thrust washer from Magnum, you can get them from O.S. Your local hobby shop may have a set, but be prepared, the parts are more expensive than you would expect. Don't ask me how I know.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Jett has it
They call it a 'stud' the advantage is if you pile your engine in at a high speed you can jsut change the stud (read as get a bolt form the store and cutting the head off) much cheaper to replace ....
Also the jett comes with a prop hub not a nut changing the length fo the stud lets you compensate from very thin cabron fiber racing props to say apc racing props ....
Steven
Yeah, but Jett don't build a 160 size 4 stroke twin. Jett built a very competitive high speed 1/2A engine from machine tool stock. This is not an available option on these 160 twins.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Bill, You are correct with the nut setup, I think Teryn wants to replace the orignal nuts with a dome nut for starting. If he just used a starter cone with a 3/4" center there would be no problem.
Cheers
Cheers
ORIGINAL: The Ghost
Cheers
Cheers
Bill, AMA 4720
WACO Brotherhood #1
ORIGINAL: The Ghost
Bill, they are what I got with the motor, I belive he wants on of these.
Cheers
Cheers
MI
ORIGINAL: Flying freak
Jett has it
Steven
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
Jett has it
Steven
Ya , thats what I was talking about. Have not seen one for years. It was just a thought, don't loose any altitude over it.
