Engine quits on a loop what could be wrong?
MN
A friend of mine has a Hanger 9 Pulse XT PNP that came with the Evolution 46 in it. It runs good in level flight, and when testing it on the ground, we can run the engine and hold the plane vertical and no problem. But while flying, if we loop the plane it quits. So are we too rich, too lean, or is there another problem?
The first thing I would check is the tank and clunk.
Try the same test you did, but do it with a half-full tank. If it continues to run while held vertically, try continuing to rotate it to inverted (Easy to do if you put a person on each wingtip).
Could be the clunk is stuck at the bottom, or you have a split somewhere in the clunk line.
