Muffler waste?
Old 10-12-2008 | 08:47 PM
Default Muffler waste?
Just curious to see if the majority of you change to a Pitts or a Macs muffler, or am I wasting my money?
Old 10-12-2008 | 09:18 PM
ChuckW's Avatar
Default RE: Muffler waste?
It really depends on the situation and the engine.
For a side mounted 2-stroke inside a cowl, a Pitts muffler is a great way to go. There are also cases when the engine is inverted and an inverted Pitts is helpful.
If a 2-stroke is mounted upright though there is rarely a reason to use anything but the stock muffler. I have used the Macs mufflers to replace broken stock mufflers on Super Tigres however and they do work great.
Of course there may be applications such as racing or other things where you will want to experiment with different mufflers or tuned pipes, possibly even building your own set up.
On 4-strokes, I have used only stock mufflers so far but I am thinking about a different setup for a Mustang that I'm currently putting together.
Basically everything has its time and place.
Old 10-12-2008 | 09:32 PM
ORIGINAL: ChuckW
Thanks for your reply.
Old 10-12-2008 | 10:55 PM
tailskid's Avatar
My Feedback: (34)
I'll do whatever it takes to keep the exhaust 'device' hidden from view!
Old 10-12-2008 | 11:19 PM
TexasAirBoss's Avatar
My Feedback: (22)
Waste of money ? lol. IF thats all the money I ever wasted on this sport, I would be in good shape !!
Old 10-13-2008 | 09:13 AM
My Feedback: (-1)
Depends mostly on the plane but I have several Bisson and Slimlines, sometimes they just fit A bunch better and/or look better. Four strokes I mostly go with stock but have made up my own header/pipes and mufflers plus I have A pitts type or two for them. Other then for racing I use pretty much what ever works best for the plane.
