 Elevon problem.... >
Elevon problem....
Elevon problem....
Old 10-13-2008 | 11:45 AM
Default Elevon problem....
Hi,
I have a RICCS RTF Mirage 2000. While putting it together I noticed upward Elevon travel differs on each wing (left up elevon travel is greater than right up elevon travel). Can you please tell me how to correct this issue and balance out the travel. Note: elevons are in balance at neutral stick and both horn/clevis adjustments are identical.
Ken
Old 10-13-2008 | 11:50 AM
MinnFlyer's Avatar
Default RE: Elevon problem....
What setup are you using? Servos? Transmitter? Etc
Old 10-13-2008 | 12:27 PM
Hi,
Setup is 4 channel Dynam NE-KO 4 transmitter, Dynam 5 ch receiver, servos came preinstalled by RICCS( unable to see manuf. name) , elevons are fastened to wing by adhesive tape strip.
thanks,
Ken
