 cleaning an engine? >
cleaning an engine?
cleaning an engine?
Old 10-28-2008 | 08:32 PM
Default cleaning an engine?
I have a few glow motors that are looking really old, even those thats are just a year or 2 old. The tops and sides darkened from fuel. Is there a cleaner out there that will clean them up?
Old 10-28-2008 | 08:43 PM
My Feedback: (13)
Default RE: cleaning an engine?
not real easily. One technique is to buy an old crock pot and stick the entire engine in it covered up with 50/50 antifreeze / water. Cook it for a day or so.
Old 10-28-2008 | 09:07 PM
ORIGINAL: DMcQuinn
Most of us use straight antifreeze. Water isn't a good thing to put into steel bearings.
Heck, my new crock pot was only $8.00 at Target.
It actually is pretty easy. After you decide the cost of the antifreeze is worth it.
Old 10-28-2008 | 09:12 PM
Dawn Power Dissolver is also pretty good. It's in a pump sprayer. And it works pretty good but you need to rinse it off. Read the directions.
It's cheaper than a crock pot, but doesn't do the insides. And you don't want to get it inside either.
Old 10-28-2008 | 09:16 PM
oldvet70's Avatar
My Feedback: (10)
I use Dawn Power Dissolver. Just follow the directions on the bottle. Basically spray it on, wait a while and wash it off. Stubborn deposits may require the use of a toothbrush to help. Best stuff I've used in over 45 years of running glow engines. Plus no toxic waste like the anti freeze method causes.
Old 10-28-2008 | 10:39 PM
Will the anti-freeze or the Dawn remove the rest of the blue paint on my OS 40 LA?
KW_Counter
Old 10-29-2008 | 06:06 AM
The antifreeze shouldn't unless the paint is already coming off.
The Dawn will oxidize if left too long, so that suggests it might.
Is that paint or anodizing?
Old 10-29-2008 | 10:04 AM
MinnFlyer's Avatar
Something worth noting:
If you use the antifreeze/Crock Pot method, DO NOT ever use the Crick Pot for food ever again. Also, label it, "Not for use with food" so no one will ever sell it in a garage sale, etc.
Old 10-29-2008 | 11:18 AM
I have engines that are over 4 years old and have little of the brown varnish or anything else, and I don't ever clean them (unless crashed, and then it's just Isopropal and carb cleaner spray). One of the biggest reasons for the varnish to form is running too lean, the engine is getting hot and cooks the castor that is on it. So if you see it starting to form, you may well be running too lean.
