Flight Packs
CA
Flight Packs
Hi, I have a Futaba FP-6NFK radio system used for my Pilot QB 40S. I am working on a Supersportster 40 as a second plane. I have been researching flight packs for the Supersportster and have found that I could purchase a complete 4 channel radio system for a few dollars more than a flight pack. Please explain why rc modelers purchase flight packs other than the reason that you have a nice, muli- model memory Tx. Thanks so much. Joe
RE: Flight Packs
Sometimes the flight pack has different servos than what you get with a 4 channel radio system. Also, if you have a multi model memory transmitter, how many spare 4 channel units do you want to have on the shelf? One gets you a buddy box, extra wall wart charger, and potentially a spare transmiter battery pack.
I have bought 'customizable' Hitec flight packs through http://www.servocity.com because they allow you to choose the receiver and servos. They also have customizable Futaba flight packs with Futaba or Hitec servos.
Most of the time the price is slightly better than buying individual parts, and shipping is free if you spend $100. Like any purchase, though, be sure to check multiple sources.
RE: Flight Packs
Once you start getting into more advanced planes you'll find that your servo requirements change. I generally buy servos based on the specific needs of the plane and if I don't have a spare receiver laying around, I'll go ahead and buy one.
RE: Flight Packs
I use a Futaba Txmiter with Hitech rciver in a couple of aircraft no probs....using different make servos than the make of the reciver may require modifcation to the plug on the servo
PA
RE: Flight Packs
ORIGINAL: GTMUSTANGCS
What receivers are compatable w/my system? Will a Futuba Rx with a Futuba crystal transmit to a Tx and crystal of a different brand?
Buy receiver crystals that are of the same brand as your receiver, don't mix those. Also be sure to get the proper crystal for your particular receiver within that brand. Many brands make single and dual conversion receivers, and they have different crystals required for each. The Tower website typically links you to the proper crystal on the receiver pages.
All of todays servos have the same pin ordering on the plugs. If you want to use Futaba servos with another brand of receiver, you may have to cut the tab off of the side of the plug. This is very easy, I use flush cut wire cutters, but you can just use an exacto knife to trim it off.
