switching recievers
TN
Hello, I use Spektrum radios & recievers. I am thinking of replacing a Spektrum 9 channel
reciever with another . Am I correct to assume that the radio settings will be the same (work) with the new reciever (once bonded)? I shouldn't need to re trim?
Indgroove
Indgroove
I think your right, but check your control positions and then after you switch the rx's check them again.
let me know how you come out, I may do the same thing some day.
sticks
sticks
Not just Spektrum but with any system all settings such as endpoints, neutrals, Expotentials and various mixs are always a function of the transmitter and the Rx will not make a difference as long as there are sufficient number of channels that may be used and its as has already been said compatible.
TN
Hello, Just confirming that the reciever switch did not matter. It's all in the transmitter.
Thanks, for all the help and advice from this forum!!!
Indgroove
Indgroove
