gyros in airplanes
OR
gyros in airplanes
I am experimenting with using a gyro on an electric powered delta wing. I want to have the gyro hold the plane level side to side. so i have it mounted verticle. In this position it responds only to axial motion as expected, However, when i connect the gyro into the aileron circuit, the servo's snap to full throw and hold. When I connect the gyro into the elevator circuit, the servo's center up as usual but I get a up/down response to axial motion. Without the gyro, all control surfaces respond correctly. I am routing the signal directly from the receiver to the gyro and then to the on board mixer and elevons.
My Feedback: (16)
RE: gyros in airplanes
This is a heli gyro.
I sounds as though your servo direction is wrong for the gyro Did you try the reversing switch?
http://www.rchobbyhelicopter.com/sto...-Sky%20EK2704B
OR
That is the gyro. Yes I tried the reversing switch and I also reversed the direction (label from front to rear), same effect. The problem is that the elevons respond the same on both sides instead of correcting for axial roll. It sure seems like the gyro should be feeding from the aileron instead of the elevator.
