AR9000???
Old 03-31-2009 | 09:53 PM
Default AR9000???
Hi,
Ive been trying many times now and I can't get the fail safe right on the ar9000. I can bind it and works fine but the fail safe doesnt work. Please tell me what I doing wrong....
Old 04-01-2009 | 06:14 AM
Default RE: AR9000???
The only idea I have is to make sure you are following the steps as outlined at the top of page G-21 in the manual.
Old 04-01-2009 | 12:58 PM
BarracudaHockey's Avatar
The default fail safe is on the throttle channel unles you:
Insert the bind plug
Power up and get fast flashing lights
Remove the bind plug
Make sure the controls are where you want them (gear up or whatever)
Power up the transmitter with the bind button, wait till you get solid lights.
Power everything off, turn on the transmitter, receiver, then turn the transmitter off and see if they do what you want.
