os 91 f/s
os 91 f/s
hey guys I have an o.s.91 that has been sitting around for about 1 1/2 years with out running.It never had any after run oil run through it,now I need the engine.What do you guys think I should do to it aside from taking it apart to clean it?
thanks Fred
thanks Fred
RE: os 91 f/s
I wouldn't even take it apart.
Put a prop on it and flip it over. If it's stiff, put some fuel in the carb to lubricate it and flip it some more.
If it feels smooth, stick it in the plane and go fly. I've had OS engines sitting longer than that with no after run oil and they still run just great.
CO
RE: os 91 f/s
I had a TH .61 that sat for almost 4 years and was really stiff. I took the muffler and glow plug off and let it soak in some old glow fuel for a few days. Rinsed it off in alcohol and it fired right up and has run great since.
ON, CANADA
RE: os 91 f/s
I would take the valve cover off and drop some oil down the pushrod tubes, then shoot some oil in the crankcase through the breather and pull the plug and drop some oil in the cylinder. Flip in over a bit and your ready to go.
