Alignment Issue
My Traxxas Slash has been veering slightly left when it should be going straight. I was wondering what the best way to fix the alignment to make the truck go straighter? thanks in advanced
TX
If both front tires are pointed in the same direction then adjust the trim on the radio
The only Traxxas type truck I have owned is this built from scratch T-Maxx. Front end adjustments are pretty self explanitory.
Thanks for the pointer. I am not visibly seeing that the tires are pointed to the left but when i accelerate it is definitely a noticeable left curve. I was messing around trying to push the tires to the right (opposite my problem) and have not been able to resolve the issue. I guess I will have to open up the owners manual. Thanks though. any more suggestions would be appreciated.
ORIGINAL: flaminheli
