JR receiver info needed!
Hello,
I am getting ready to start a build on a Great Planes Pitts Special (33% size) and I am looking at the best receiver for my application. I am running a JR SX600 6 channel radio on 72mhz channel 29 and need to buy another receiver for the airplane. I have looked at the JR r770s and the JR r649 s-pcm. The pricing between the two isn't too bad, but I am not sure which is the best "bang for the buck". I read on the horizonhobby site and was led to believe that s-pcm would be the best, but will this work with my kind of transmitter? I am sure it would but before I buy would like some opinions. Is this the best receiver for my application? If not can you suggest something better? Thanks in advance!
RE: JR receiver info needed!
I am guessing i couldnt find out for sure but i doubt those receivers would work they are pcm and i am mostly sure your radio is ppm. I would look around for a JR700 or one of the other ppm receivers.
something like this would work
http://cgi.ebay.com/BRAND-NEW-JR-R700-7-Ch-SLIMELINE-72MH-FM-RECEIVER_W0QQitemZ230357763633QQcmdZViewItemQQptZR adio_Control_Parts_Accessories?hash=item35a2648631&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|293%3A1| 294%3A50
ok i did find that horizon still sells them
http://www.horizonhobby.com/Products...odID=JRPR700**
my 72 stuff i use those and they are light and small easy to get in any airplane.
ORIGINAL: spitfire66
Thank you. Your right. I called up horizon hobby to see what was compatable. I think I need to go to pcm. Thanks for looking.
My Feedback: (25)
The SX600 is the JR "SPORT" radio. It is a PPM not PCM transmitter. You cannot use a PCM receiver with it. Listed here are the JR brand receivers per their website that are compatable with your transmitter.
Also, keep in mind that any POSITIVE shift Hitec 6 channel receiver with the correct channel crystal will work too.
RECEIVERS
Item Number
Description
Retail Price
Available For
JSP30600
6 Channel Universal FM Receiver
$89.99
$64.99
JSP30610
6 Channel UltraLite Receiver (Pos Shift)
$69.99
$54.99
JSP30615
6 Channel UltraLite Receiver (Neg Shift)
$69.99
$54.99
RECEIVERS
Item Number
Description
Retail Price
Available For
JSP30600
$89.99
$64.99
JSP30610
$69.99
$54.99
JSP30615
$69.99
$54.99
