OS FP .15 Quits in Air
OS FP 15, bought used.
On the ground, ran 2 tanks through, it runs like a champ. Put a flight on it (combat alum/coro) and it and quits on half-tank. Tank is fine, pick up and clunk are good. Seems to get way too hot. Test is repeatable with 3 flights. Test flights normal, flat and level right hand circuit. 10mph wind at most. All new fuel lines. No nicks or leaks, triple checked.
I richen the mixture, same thing, only it's a mess of fuel.
Being used for combat, aluminum rail with coroplast wing and tailfeathers. 7x5 and 8x3 props same results.
Being used, this engine looks great.
Starting points for airbleed and mixture? Plug? Book OS site says #8 plug.
Last, are there any intricacies inherent only to this model engine that may help?
Jason
Jason
My Feedback: (108)
RE: OS FP .15 Quits in Air
It sounds like you are flying an HOR with the aluminum fuse. Is it possible that your fuel is foaming from vibration? My tank is mounted with a load of foam behind it to keep the foaming and air bubbles down. The other issue that we discovered is the motor mount itself. We use one that we get from Wal Mart as the material that it is made from is different from other cutting boards. My first mount was from a cutting board from another store and it allowed the engine to shake and the vibration was bad. I got the Wal mart board and my vibration and engine problems are gone. Good Luck, Dave
