How to set up dual elevator with AR6200?
MO
Hey guys
I'm trying to figure out how to set up dual elevator and ailerons on a ar6200 and dx7.
I see the directions online on how to set up dual elevator on the DX7 with the ar9000 or a 7 channel receiver, but how can I do it with the ar6200?
I guess I can use the mix 5, like in the directions, but instead of sending it to aux2, send it to the gear. But how do I deactivate the gear?
thanks!
Tim
thanks!
Tim
When you go into the first setup menu, the same one where you enter the model name you can inhibit the gear switch and other switches. It's been a while since I set one up so I forget exactly how it is worded on the screen but it is something like that.
