Foam cleanner
Guys,
Is there any way to remove a dry epoxy from a foam wing without scratching it or removing the painting?
I assembled a SU-34 from HL and made a not so good work when joining the wing to the fuselage, and left some epoxy in a shinny strip on the wing root.
It`s not matching the opaque finishing from the plane.
I think I know the answer, but would like to hear from you guys.
Chears!
Kirk
Chears!
Kirk
Thanks Jim,
Nice clue!
I`m going to try that.
Do you know if Top Flite LustreKote is going to work?
I`m just thinking about which kind of lacquer I can securely use on the foam.
Cheers
Nice clue!
Cheers
