Help w/ Fliton Extra 330S
Hello All,
After so long I finally finished my Fliton Extra 330S with the following setup:
•AXI 4130/16 motor
•Jeti 77 Opto
•APC 17x10 narrow prop
•Castle 10 amp BEC
•Dual Batteries Thunder Power 3700mAh 11.1V each
Weights 6.823 lb (3.095 kg.) total w/ battery installed.
Can someone help me and tell how should be my estimated flight time with this setup?
•AXI 4130/16 motor
•Jeti 77 Opto
•Castle 10 amp BEC
