 Spliiter for the battery >
Old 01-27-2010 | 04:01 PM
Default Spliiter for the battery
Hi,
I want to power two of these EDF's with this battery.
EDF -
http://www.hobbycity.com/hobbyking/s...idproduct=5484
Lipo -
http://www.hobbycity.com/hobbyking/s...idproduct=9506
What kind of splitter should i use ? Can anyone post the link of the item .
Thanx ...
Old 01-27-2010 | 04:19 PM
huck1199's Avatar
Default RE: Spliiter for the battery
Are you thinking of using separate ESCs?</p>
Old 01-27-2010 | 09:25 PM
The Ghost's Avatar
You would need two of [link=http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=2166&Product_Name=TURNIG Y_Plush_60amp_Speed_Controller]THESE[/link]as the rating of the motor is 45amp.
If you are going to use the ESC to power the reciver you will have to remove one of the red wires from one speed controler.
Cheers
Old 01-27-2010 | 10:51 PM
I m planning to use two 60A ESC for these EDF's.
http://www.hobbycity.com/hobbyking/s...eed_Controller
I want to know that how can i split the power(connector or adapter) from battery to power these two EDF's.
Is these any kind of splitter available in market ?
Old 01-28-2010 | 05:36 AM
The Ghost's Avatar
You just need to make up a lead to join the two power cables together so they can be joined to the one battery. Hobbycity don't do the cable you would need. Just join(power) the two red cables together and the two black ones together and then fit the require conector to suit the battery.
Cheers
