?Reverse Running OS61 FSR How-To?
I have a pusher prop configuration where I'd like my 3-piece OS 61 to run backwards so I can use standard props. I know to make this happen all I need to do is rotate the front crank housing 90 degrees one way or another. I know I've got a 50-50 chance of getting it right (or wrong) the first time but . . . Can anybody share with me which way to rotate the housing? Any clues would be appreciated.
Mike
Mike
